Home Forums Vinyl Cutter Discussions Roland Cutters VP540 Motor error when cutting on full 50m roll
  • VP540 Motor error when cutting on full 50m roll
    Posted by John Dorling on 31 March 2010 at 15:59
    Hi All
    Is my Versacamm really weak or is it normal to get a motor error when cutting on a full roll of 1220 vinyl? It is the feed motor not the scan motor so I assume that the weight of the roll is too much for it? Is this right and if so is there anything I can do about it apart from unrolling the media before I start?
    Dan Osterbery replied 15 years, 9 months ago 2 Members · 3 Replies
  • Dan Osterbery
    31 March 2010 at 16:53
    are you using the clear plastic rollers? is the brake off?
  • John Dorling
    31 March 2010 at 17:01
    Yes I am and yes it is
  • Dan Osterbery
    31 March 2010 at 17:15
    sorry matey! my only suggestion would be to roll out a couple of metres of vinyl and let it sit just above the ground! have you turnrd off the function that pulls the vinyl though and pulls it back before it cuts? mine always used to stop when using that function????
