Home Forums Sign Making Discussions Vehicle Wrapping Vivaro Panels Advice
  • Vivaro Panels Advice
    Posted by Joseph Helm on 20 November 2008 at 22:21
    Firstly, if this is the wrong place to post this, I’m sorry and please move it.
    I did a Vauxhall Vivaro van a couple of week back
    It had a large image on the sides and back panel, which I didn’t cut around the contour on (customer request).
    I’ve got another one to do next week, and wanted to know the best way to make sure I get a good cut around it (same customer, new request).
    Any ideas or comments are more than welcome.
    Joseph
    Peter Normington replied 17 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Kevin Flowers
    20 November 2008 at 22:27
    apply your graphic & then run either fine line masking tape or a 5mm vinyl stripe around the shape you want to contour, then use this as a guide for you blade, remember not to cut to deep.
    20 November 2008 at 22:30
    Joseph,
    sorry mate, getting late, not sure what you need to do,
    di you need to cut the print so it fits in the panel?
  • Joseph Helm
    20 November 2008 at 22:34
    quote Peter Normington:
    Joseph,
    yes 🙂
  • David Rogers
    20 November 2008 at 22:45
    I use two methods.
    Kevin’s – thin ‘coachline’ of vinyl & run the scalpel along it’s edge as a guide.
    or freehand, ‘fast’ with fluid movements.
    Both require brand new scalpel blades and absolute KNOWLEDGE & FAITH that you are only cutting through 80-90% of the way so you never actually cut through to the paint.
    Pre-sizing a panel is possible before manufacture but getting it perfect can be a pain. Alternative is if you can manually knife the areas needing shaped on the bench after producing a template to cut to.
    20 November 2008 at 22:47
    may be long winded but you only do it once. per type of van
    take the panel out of the drawing and measure and adjust to best guess.
    plot with a pen to paper cut it out and try it.
    you will see the adjustments to make alter drawing and re-plot should now be correct.
    use that outline as the print and cut boundary.
    been cutting on the vehicle for years and still hate doing it, so got used to doing this.
    ought to sell a disk of cutable panels, 😉 😉
  • Joseph Helm
    20 November 2008 at 22:54
    Thanks guys, ill give the suggestions a try!
    20 November 2008 at 23:00
    Joseph
    I make a template, you only need to do it once, then you can re-use it.
    use some backing paper or even a piece of vinyl, tack it over the panel with masking tape, press it into the recess using your fingers and as you do, mark the low point with a pencil/stabilo
    remove and using a sharp scissors cut out the shape, use this to transfer to your print, and cut out the same way.
    There are other methods, but I find this way the best,
