Home › Forums › Sign Making Discussions › General Sign Topics › Vista – Ashby Inserts..What do people use
Posted by Martin Oxenham on 19 June 2011 at 10:11What are people using for these inserts ? I know you can use simply paper or vinyl text Evan printed vinyl with the paper left on but what do you use outdoors.
John Harding replied 14 years, 6 months ago 5 Members · 7 Replies -
not on these systems in particular, but similar… ive used hydrasol and the like… by that i mean the polyester grey backed media used on pop-up and roll-up stands.
Yes Rob I thought about using that as its sort of a waterproof paper.
Poster paper, we keep quite a heavy poster paper in stock and that does the job just fine.
Sorry, didn’t read the post properly! I think we have only done internal ones. I think the hydrosol idea is good or if you can get away with .75mm or .5mm pvc (limited size sheets) with vinyl laminated and applied to face
We use vinyl with laminate mounted onto 1mm thick forex. You can also apply vinyl/lam onto the clear polycarb (think thats what it is) that comes in the directories
Andy
Martin apply laminated graphic to the outside of the supplied acrylic insert, I have done it and it works and looks good
John 😀
