Home Forums Vinyl Cutter Discussions General Cutter topics Vista 64 bit systems.
  • Vista 64 bit systems.
    Posted by yipee on 14 October 2007 at 16:06
    Hi, I’m looking to buy a cutting machine and my OS is vista 64bit. Does anyone know of any machines that run on this platform ?
    So far I’m hearing conflicting reports. One says that no cutting systems will run on 64bit.. and another (Rabbit) saying there’s will.
    If anyone has any suggestions I’d be most grateful… Thanks
    yipee replied 18 years, 2 months ago 2 Members · 2 Replies
  • Russell Huffer
    14 October 2007 at 16:32
    I run Vista 64 bit at home, one program that will not install is Adobe Indesign, however Illistrator works fine.
    It is not the make / model of cutter that will be your problem it is the software you use to drive it and to be fair to vista it has run all software i have needed except Indesign will not load and Cad Pro is unstable. I have had my copy of Flexi running on this vista 64 bit but have not cut as this pc is at home so i just use it for design, then cut when back in the office.
    As Flexi works there is a good chance the other mainstream ones will.
    Russell.
  • yipee
    14 October 2007 at 16:55
    Ah, so I was looking at it the wrong way round. Well, I’m learning 🙂 Thank you very much for that info.
