Home Forums Printing Discussions Mimaki Printers vinylmaster pdfs in onyx colour problem
  • vinylmaster pdfs in onyx colour problem
    Posted by Simon Prior on 4 October 2013 at 11:56
    I’m really struggling to export pdfs and use them in onyx. Everything seems to look great after I’ve exported it in the preview you get but when I import it in to onyx it seems to come through with all muted colours. I don’t understand what i’m doing wrong, I’ve experimented with saving as a pdf and converting colours to cmyk, retaining spot colours etc, but am now scratching my head somewhat.
    I’m hoping somebody may be able to throw some much needed light on the problem!
    thanks in advance if you have any suggestions
    Simon
    Alan Drury replied 12 years, 2 months ago 3 Members · 3 Replies
  • Reza Faezi
    4 October 2013 at 11:58
    Ive never used onyx myself, but have you tried exporting it as something else ie an AI or EPS
  • John Dorling
    4 October 2013 at 12:18
    Do you have any transparencies used in the document? Try saving as PDF 1.5.
    7 October 2013 at 07:24
    It could be a colour management issue, if you are designing in RGB then a cmyk conversion can often give duller colours. CMYK has a smaller colour gamut so some RGB colours are not possible to print. Colour management will allow you to view what will print so you can do your adjustments on screen with more predictable print results.
    Transparencies can be a problem with some RIPs – manually flattening is one answer but you may wnt to experiment with pdf X1a export as that is normally a good solution.
    alan D
