Home Forums Sign Making Discussions Vehicle Wrapping vinyl that can be applied to "bumpy" surface?
  • vinyl that can be applied to "bumpy" surface?
    Posted by John Blennerhassett on 22 November 2006 at 15:16
    Hi All, am looking for a a digital vinyl that i can apply to a "bumpy" painted finish, i.e. needs to have a thick layer of adhesive, can anyone recommend?
    Sam Windle replied 19 years, 1 month ago 2 Members · 3 Replies
  • Sam Windle
    22 November 2006 at 15:34
    You’l be lucky to find a good printing vinyl for that sort of surface. Probably best to mount graphic onto a PVC or a Foamex board then apply a foam tape. If not the Ri-Jet 75 works well with corrugated surfaces. Hope this help.
    Sam
  • John Blennerhassett
    22 November 2006 at 16:15
    thanks Sam, hadn’t thought of a foam tape, will look into in more detail, the Ri-Jet is only available in semi-permanent adhesive, so probably not suitable, thanks anyway
  • Sam Windle
    22 November 2006 at 16:23
    No problem John, but just to let you know, the Ri-Jet 100 is a semi-permanent. But the Ri-Jet 75 is available in a permanent adhesive.
    Sam
