Home Forums Sign Making Discussions Vinyl vinyl required for bus window graphics?
  • vinyl required for bus window graphics?
    Posted by marty_j on 4 February 2004 at 14:54
    I’m sure i read this somewhere before in the forums, but can’t find it now.
    Does anyone know the name of the perferated printable material used on bus windows.
    I’m sure there is a 38cm sprocketed version aviable as the little ‘portfolio’ thing I got with my edge had a printed sample.
    Martin
    Chris Wool replied 21 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • chris@lazerpics
    4 February 2004 at 15:05
    Hi marty,
    The name your after is, one vision or through vision I have used
    it before. have a look at goldshield van in show us you stuff (oogle)
  • signdevil
    4 February 2004 at 15:41
    Spandex sell this product, it is called ‘contravision’ and is available in 380 sprocketed for the Edge. This is expensive stuff and most potential customers will pass a bowling ball when they are fully aware of the costs involved. The end effect is great though and as we all know, you’ve gotta be prepared to pay for that.
  • marty_j
    4 February 2004 at 18:39
    Thanks for your help guys, brain wasn’t working to its full potential today.
    4 February 2004 at 21:39
    if your stuck.. cut vinyl strips verticle or horizontal.
    each line 2mm wide space 2mm then 2mm line and so on.. cut this to the width of your print area. print your graphic over the cut area then weed away every second line. you end up with the exact same effect as clear veiw but this time the water wont get caught in the holes 😉
    doesnt cost you anymore than normal vinyl too 😀
  • signdevil
    5 February 2004 at 13:35
    Hey Rob, that is a damn good idea and one which I will defo be using.
    Cheers!
  • marty_j
    5 February 2004 at 13:38
    Just explained the strip idea to my ‘boss’ and the difference in cost. Saves me having to order in anymore material as well.
    5 February 2004 at 17:10
    thanks for reminding me
    i did this about 2 years ago but mounted it on black before cutting so as to be black from the inside end result to thick like me
    are you saying that it works with out the black back i can see it will be ok from the outside but……
    5 February 2004 at 19:11
    gave the soljet a pasteing just done one if it was not dark & raining ide fitt it … it took longer to cut than print now weeded treable banding 😆
