Vinyl removing wheel tools – advice needed, please?
Hi Guys
We are looking at quicker ways to remove vinyl graphics and wraps from vehicles.
Currently we use the good old fashioned method of heat them up and peel them off but this is quite slow and can leave glue behind, which then needs to be removed with chemicals.
We are interested in getting a vinyl removal tool like this one http://www.signgeer.com/product/mbx-kit-electric-270
which is supposed to strip graphics easily. It is a rubber wheel powered by electric or a compressor which spins it at high speed and strips the vinyl away like a grinder.Has anyone used one of these and if so what was it like? Pros and Cons?
It is quite expensive but if it speeds the process up then it is worth it in the long run!Thanks
Adam
