Home › Forums › Sign Making Discussions › Vinyl › Vinyl removal with no power
Posted by Daniel Evans on 17 June 2015 at 11:19Hey guys
I’ve got a job on Friday removing some vinyl off a sign, there’s no power so I’m thinking i’ll use a blow torch (lightly) to heat the vinyl up as this is what I hear some americans do.
Has anyone done this and can you recommend a blow torch preferably a mini one
Mo Gillis-Coates replied 10 years, 4 months ago 4 Members · 6 Replies -
Hi Daniel
What substrate are you removing from ( Glass, Paint, laminate ) and is it inside or outside ? -
Hi Iain
It’s a white aluminium tray, it’s outside but i need to do it early in the morning so they’ll be no power.
Use a big / standard plumbers torch – get one with a self igniter too and waft it over a larger area to raise the temp evenly.
Makes for a wider spread of heat that you can control at a distance. Use them all the time when on site or doing vans in the cold weather as it’s faster than dragging out the heat gun…careful, careful though.
Thanks Dave
Just before you replied though I went and bought a dremel gas blow torch getting delivered tomorrow, I’ll see what that’s like, easier enough to hold when you’re up a ladder too and seems powerful enough to heat so vinyl (I think)
Anyone used Vinyl off?
It seems pretty good in the videos but you don’t know for sure.
Is it a solid vinyl or cut vinyl ?
I find a lot depends on how long the vinyl has been in situe , and also, the make of vinyl as adhesive characteristics are quite dramatic on some.
Opt for the heat method to start, but I still find it easier to remove using a cardboard core and rolling it off.
Sometimes when you heat it, the compound of the adhesive can change and leave a load of residue on the substrate which you then have to clean off.
I’d take equipment for every eventuality and see what works best on the day.Where about is the job ?
One that works for me it hot almost boiling water…. depending on how big the sign is though, if on site with no power I would use a flask of it, but you may need a few flasks if its big. However I have only used this on vehicles in the past with cut lettering vinyl.
So far its only failed me once on a vinyl that has been on so long, it took the paint off with it
Hope this helps
BigMo
