Vinyl Printer Help – White Ink or White Back
Hi there,
Iām new to the forum and would really appreciate some advice.
I’ve been printing large format photos using an Epson 9880, laminating (drytac jetmounter) an optically clear double-sided adhesive to the face of the image and then laminating the result a second time to Acrylic.
I.e. Sandwich of Photo, Adhesive Film and Acrylic.
I do this for photographers and over the last couple of years I’ve managed to get this down to fine art. However I have few problems:
1) Its time consuming and with repeat business I would now like to speed things up.
2) Laminating adhesive to photo and then adhesive to acrylic, I can sometimes get a dust particle or small bubble trapped and have to start over (even with tac cloths and using IPA spay to remove static etc) as they show through.
3) I would like consumers to be able to hang the product in moist or even wet environments inside the house (kitchens and bathroom).Therefore I was wondering if it might be better to now invest in an eco solvent / solvent printer. My thinking being that I could perhaps print (mirror image) straight onto clear vinyl and then mount straight to the acrylic before laminating a white backing vinyl. This would be less risking regarding particles, as the backing is not too visible as its just there to make the colours more opaque. This would hopefully save me time whilst ending up with a product that is more resistant to moisture.
This leaves me with a few questions based on the fact that the result must give a photo quality image.
1) To start with, does this sound logical?
2) Could I use a four colour (say Roland SP series) and back with white vinyl on the understanding that there is a second possibility of particles showing through on the unprinted areas of the clear vinyl.
3) To get photo quality images would I be better off spending money on the Roland VS series with white inks, backed with white vinyl to make the colours look more opaque?
4) Is laminating vinyl to vinyl quite easy with regards to static and bubbles etc.Again, thanks for any help.
Paul.
