Home Forums Vinyl Cutter Discussions Summa Cutters Vinyl not cutting correctly, advice please?
  • Vinyl not cutting correctly, advice please?
    Posted by Iain George on 25 January 2020 at 10:46
    Can someone please point me in the direction of which menu to resolve this issue please. Ot is an HP 54 basic cutter but is actually a rebranded Summa.I have cut this artwork before with no issues. I have not changed any settings on the machine and this is now how the “O” s are cutting and also this issue with the “D” in fact most of the letters look odd.
    David Stevenson replied 5 years, 10 months ago 6 Members · 7 Replies
  • 7 Replies
  • John Thomson
    25 January 2020 at 12:06
    I’d start looking at the simple obvious things.
    carriage moving freely? blade rotating smoothly? no change made to blade offset or overcut settings in your software? or any settings on the cutter itself?
    Hope this helps.
  • Iain George
    25 January 2020 at 12:14
    I have changed nothing. Other works have cut perfectly between this job.
    Have just recut it still haven’t changed any settings and it is spot on. Maybe a bit cold in here this morning and the vinyl was to cold.
  • Nigel Poulter
    25 January 2020 at 14:25
    How much work has the blade done ? does it need replacing, beccause once you loose the edge of the blade cutters can do very strange things.
  • Iain George
    25 January 2020 at 14:28
    quote Nigel Poulter:
    Only had it since November. Most probably not more than 100 meters and only normal vinyl or laminated for print and cut.
  • Pane Talev
    25 January 2020 at 15:26
    This happens to me when vinyl is loose on the mashine. Happens to the letter further away from the roller. Therefore I always cut bigger objects in the first line and then detailed work further down the roll where the vinyl roll will fall in the front basket and create a good tension.
    Taping a off cut vinyl piece in the front before the mashine start also helps to have tension.
  • John Lacey
    27 January 2020 at 08:26
    I agree that this is a hardware issue. It seems to me the pinch rollers are not clamping the vinyl correctly. Perhaps there is a small piece of vinyl stuck to the grit roller allowing the vinyl to ‘skid’ at certain points in the X-Y feed? Dunno, just an idea..
  • David Stevenson
    28 January 2020 at 14:26
    This may sound stupid but is your blade holder secure in the machine? Ours was loose one day and causing a very similar fault. Felt silly when I found it 🙁
