Home Forums Sign Making Discussions Vinyl vinyl for pvc ?
  • vinyl for pvc ?
    Posted by Richard Davies on 16 November 2008 at 22:54
    hiya
    I saw mentioned somewhere that there is a special vinyl for taught liner sides ?
    for application to the PVC curtains.
    who would supply this and what is it called.. ?
    regards
    richard
    Vic Adair replied 17 years ago 8 Members · 10 Replies
  • 10 Replies
    16 November 2008 at 23:30
    All print supplies stock the stuff you need, but beware it is VERY stickly, and once applied, its applied, or so I have heard 😉
  • Cameron Steer
    17 November 2008 at 13:20
    Hi There,
    If you havent used it before , peter is right its VERY difficult to remove , cheaper infact to get a new tarpaulin than pay the man hours to shift it.
  • Derek Heron
    17 November 2008 at 19:04
    i have used the truck vinyl
    not sure how long it takes for the glue to go off
    but when i used it you could peel it back off no problem but the following day don’t even think about it.
    just though i would mention it
    derek
  • Richard Davies
    17 November 2008 at 23:05
    Hiya
    That sounds like the stuff i need, would you know if its expensive ?
    I don’t need huge amounts but it will be used in a marine environment so has to be good.
    regards
    Richard
    17 November 2008 at 23:11
    It depends how you classify expensive, if it does the job, and your customer is happy then its not expensive.
    Call all print supplies for a price, it is probably more reasonable than you think
  • Peter Cox
    18 November 2008 at 09:33
    If it was me and it was only a quite simple design, I would stencil and ink it……..Simple to do and will last forever.
    Also miles cheaper
  • Richard Davies
    18 November 2008 at 13:14
    hiya
    yup, a stencil and Ink sounds like a really good idea
    except I have no idea what you are talking about hehehe..
    i get the principle but have no idea where to get the ink and is the stencil cut on the plotter ?
    regards
    Richard
  • Neil Davey
    18 November 2008 at 13:45
    Grey Macmask which can be cut on your plotter.
    Apollo ink and the appropriate thinner.
    But be warned, once it goes on you can’t remove it without ruining your canvas.
    Neil
  • Ade Brown
    18 November 2008 at 14:07
    apa do a vinyl specially for curtains
    Ade
  • Vic Adair
    18 November 2008 at 16:56
    Avery SIGNFLEX Robert Horne sell it. Can be wet applied but in this cold weather best dry.
    Vic
