Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Vinyl Cutting issue, help and advice please?
  • Vinyl Cutting issue, help and advice please?
    Posted by Jayden Woodward on 7 June 2019 at 10:45
    I am having a bit of an issue when cutting anything that has an inner ‘circle’ letters such as O a d etc.
    I have a Graphtec CE-3000-60 running off cutting master 2 from illustrator cs6.
    I know it’s an old machine but it’s cutting everything else perfect just seems to be the inner section of certain things.
    I have attached an image that shows a bit better
    Thanks in advance
    Jayden Woodward replied 6 years, 4 months ago 2 Members · 2 Replies
  • Simon Worrall
    7 June 2019 at 11:04
    Jayden
    Looking at your photo, the corners of the H next to the O are not perfect at all – unless it is just very blurred I would say
    your blade offset is way off.
  • Jayden Woodward
    7 June 2019 at 12:17
    How would you change this on cutting master. I know you can change the offset on the machine itself
