Home Forums Vinyl Cutter Discussions General Cutter topics Vinyl cutter advice
  • Vinyl cutter advice
    Posted by Blade kites on 29 March 2007 at 19:32
    Hi All im new to the forum.
    Im after a bit of advice if pos
    Im not a sign company but own a Uk Distribution company called
    selling blade kites,
    I am a sole distributor for the uk importing Kitesurfing equipment
    I do lot of promotional events giving out free stickers t-shirts.#Wich cost me a lot of money as i dont get any return from them
    Im looking at getting a potter cutter for my business as to try to save a little bit of cash,
    But there are so many about,
    My wife uses mac for the design work eg. flyers and adverts for the mags
    so im after a cheap plotter ,
    nothing to big but will work on mac ,
    all it for is doing promo stickers and to print my own t-shirts for the demos
    any ideas would be greatfull
    iv been looking at a creation ps240 or there is a creation uk630 on ebay
    click here
    could any please put me in the right direction
    i have a small buget 0f about £300
    carl
    mod-edit
    Steve Lomax replied 18 years, 7 months ago 5 Members · 6 Replies
  • Glen Mathers
    29 March 2007 at 20:47
    Hi, i use and have been using a P-cut 630 for the last 3 years, it works a treat, never had any bother at all.
    If you can, try and get 1 with a serial connection because everyone who seems to get a USB version has trouble setting them up 😀
    Glen
  • Steve Lomax
    31 March 2007 at 11:32
    I’m a novice with an (eBay) Rabbit plotter/cutter. My set up cost was about £370 including 5 x 5 metre rolls of 60cm vinyl, application tape and a basic tool kit. The Rabbit cutter has serial (com) and USB inputs. I found the USB much easier to set up than the com port. Took me about 30mins to get it going once everything was assembled. I’m really pleased with the results and now have a smart van and loads of promo stickers.
    I was going to post an image but that may be seen as blatant advertising!
  • Blade kites
    1 April 2007 at 08:27
    Cheers Guys,
    I was looking at both the Plotters but could’nt find much on the rabbit.
    So i’ve just invested in a P-cut 630,
    So im on my way,
    Thanks again ,
    carl
  • v8adam
    1 May 2007 at 11:58
    quote Steve Lomax:
    Steve, did you have problems with the Rabbit when you were cutting? ifso how did you fix it?
  • David-Foster-
    1 May 2007 at 14:18
    Carl
    Did you get your plotter working with the Mac?
  • Steve Lomax
    17 May 2007 at 16:55
    quote :
    I don’t use it a great deal – just for personal use, but I do get the occasional letter that the cutter has not quite made complete. I’m only talking a fraction of a millimeter and its not really a problem on letters over 30 mm tall. It is a problem with small letters (10mm). The "ball end" weeding tool helps. There’s been quite a lot of talk about this problem being offset setting – apparently not adjustable on a rabbit. If you hear of any info on this cutter please pass it on. I will do likewise of course.
