Home Forums Sign Making Discussions Vinyl Vinyl application, Float-on wet or not?
  • Vinyl application, Float-on wet or not?
    Posted by Billy Lawton on 16 November 2011 at 08:24
    Hi everyone – doing my first application today – only a small job on a car – just text. Should I use float – on solution spray just for text – I don’t obviously want any bubles as the guy (a mate) is a bit fussy.
    Just wondering if you all use a spray (float or soap) for every vinyl application?
    I appreciate your wise words.
    Billy
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    Tim Painter replied 13 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • David-Foster-
    16 November 2011 at 08:42
    Hi Billy, I am not the most experienced here but I think my answer is what you will get from others. If it is just vinyl lettering on a car, do it dry. I think if it is wet the lettering would come away with the app tape unless you left it a long time to dry first.
    I presume you have practiced on your own car first to get the feel of it? It’s hard to get bubbles on just lettering. Flood coating is another matter :lol1:
  • Chris Windebank
    16 November 2011 at 08:44
    Do it dry, its only leteers so should be no problem. I see in another thread you have wasted 5m of vinyl, consider this practice material.
  • Billy Lawton
    16 November 2011 at 08:46
    Brilliant- thanks David – dry it is! Yes I’ve had plenty of practice – my uncle has a body shop and he’s mounted a "door" on a wall that I’ve practiced on.
    Thank you – cold out there today!!
  • Billy Lawton
    16 November 2011 at 08:48
    Thanks Chris – yep – I’ve used the 5m as practice! Good advice gents.
    :police: Mod-Edit
  • Peter Dee
    16 November 2011 at 09:11
    Billy, I usually use a firm felt squeegee on vehicles as they conform better on the curves. I then rub down with a plastic one.
    Don’t do it wet, you’ll be there all day.
  • Lee Attewell
    16 November 2011 at 10:23
    Like the other boys have said mate do it dry. Use a good pressure on your squeegee just using the sharp edge to hit the vinyl, keep using over lapping strokes and expect to re do the job 😉
    Just another bit, little tiny bubbles will disappear over a week or so depending on weather.
    Good on ya for giving it a go.
  • Billy Lawton
    16 November 2011 at 17:33
    Thanks guys!
  • Tim Painter
    16 November 2011 at 22:08
    As you said it is getting colder out, I would give it some heat after application to starts the glues working.
    Also prep the surface well to degrease.
