Home Forums Sign Making Discussions General Sign Topics Vinyl & glue removal
  • Vinyl & glue removal
    Posted by Adam Triggs on 28 March 2007 at 08:36
    Hi All,
    Another one from the new kid I’m afraid.
    I’ have a sign which has old vinyl lettering on. what is the best way to remove the vinyl and glue before I stick new letters on top ?
    Looked at the MBX Hand Held remover from JAG, Looks really smart but at £280 I need to know if it is really worth the expense in time saving or is there a more cost effective option ?
    Adam
    Martin Pearson replied 18 years, 9 months ago 10 Members · 13 Replies
  • 13 Replies
  • Gavin MacMillan
    28 March 2007 at 08:50
    The MBX is a useful tool but not always the answer. Unless it’s class1 reflective you’ll be able to get buy with a scraper and some good finger nails. For bigger areas you can use a hair dryer (I prefer this to a heat gun) or a wall paper steamer, this is a great tool and if you alter the time its left on the surface and angle you pull the vinyl away you can usually get it to take the gum as well. Watch the heat on thin foam though as it may not go back to the right shape if you put too much heat on it!
    For removing gum we use the ‘rapid’ remover from APS, but there are alternatives from doro tape and grafityp as well. All get recommended on here
    Hope this helps
    Gavin
  • James Martin
    28 March 2007 at 08:53
    The last time I removed vinyl it was from a van.
    I used a paint stripping heat gun (carefully) and softened a corner of a letter then I found it would peel off no bother.
    Time before that it was a shop sign and the customer wanted a previous sign recovered.
    Again with the heat gun but this time I needed a metal scrapper so I guess it was just like taking off wallpaper.
    As for removing the glue on the shop sign I used white spirit, a rag, and elbow grease.
    Ive never used a rotary type machine but from what I have picked up form reading other posts about vinyl removal using the search site box unless its special vinyl or really small lettering most people dont bother with special rotary machines.
    I think you can get a polypropylene chisel as well that isnt as hard on the substrate but I haven’t found one yet.
    Hope this helps
    Jimmy
  • Derek Heron
    28 March 2007 at 09:01
    just to add to the above little pink chiselers i think they are called and they are pink .from print one uk are great for lifting the edges of warmed vinyl save your nails and don’t damage the paint also auto glym tar remover is good for small areas.
    i use my chiseler with the steamer for large areas and the hot gun for small text etc
    Derek
  • Adam Triggs
    28 March 2007 at 09:09
    Cheers Guys,
    Not a large amount of text but it is on a VW dealership sign and I cannot replace the main unit if i melt it or something.
    Appreciate your help and the wallpaper steam gun sound like a great idea. so I get in my shed and fish it out.
    Adam
  • Dave Harrison
    28 March 2007 at 09:37
    when using heat guns heat the area around the vinyl and not the vinyl directly this method tends to leave less glue behind. As for glue removal I use a 3M product thats basically called vinyl glue removal system or something like that, comes in a green box about £15 available from car body shop suppliers
  • gordon bradshaw
    28 March 2007 at 09:43
    i find that meths is the best and cheapest solvent remover along with a battered old hairdryer . best advice i could give is patience if you take your time youre more likely to get it off in large pieces
    28 March 2007 at 09:46
    quote :
    when the water in the container runs out it glows a nice shade of pink then goes pop i bust 2 in the last year throu not thinking. but work very well.
  • Jayne Marsh
    28 March 2007 at 09:56
    I use fingernails and a wallpaper scraper ( very very carefully so as not to scratch the surface ) then remove glue using Rapid prep from APS and sometimes Jizer . :lol1:
  • Adam Triggs
    28 March 2007 at 10:18
    Cheers All,
    Great advice, Saving me loads of time on trial and error
    I’ll be buying a big round at sign UK 😛
    Adam
    28 March 2007 at 10:34
    I heat with a hair dryer (a heat gun can be too hot) and use a L’il Chizler (50¢ from a sign supply or free at a trade show)
    Spray with Rapid Remover, let the glue turn into goo and scrape off carefully with the chizler.
    You may have to repeat this step.
    Then clean with Rapid Prep.
    You’ll go thru lots of paper towels!
    I used mineral spirits once (my own truck) a year later when I removed the lettering it took off the clear coat.
    I wanted to get a wallpaper steamer but I heard it won’t work on reflective vinyl.
    28 March 2007 at 11:18
    Adam, some good tips above, it is really like most things, try different methods and see what works best for yourself. I personally don’t like heat guns because it is far to easy to apply to much heat. Even when I am fitting I use a hair dryer and only get the heat gun out once the job is completed as a hair dryer doesn’t produce enough heat to ensure the vinyl is fitted properly.
    For removing small amounts I normally use the hairdryer and one of the little chizlers from Jag and for large areas the wall paper stripper. For glue removal and general cleaning before applying Vinyl I use IPA (Isopropyl Alcohol) which I believe does a better job than just about anything else but some people don’t like because it evaporates very quickly.
  • Adam Triggs
    31 March 2007 at 19:52
    Hi Martin and All
    The Isopropyl Alcohol worked a treat with the little chisler, The Direction sign had been there for years and we’ve now updated it and made it look new.
    Cheers All.
    Kind regards
    Adam
    1 April 2007 at 00:30
    Adam, glad to hear that everything went so well, the little chizlers are quite a handy tool especially as I don’t really have any finger nails. I just wish they did them in some other colours.
