Home Forums Sign Making Discussions Vinyl Vinyl & App Tape
  • Vinyl & App Tape
    Posted by Edward Thompson on 10 November 2011 at 09:19
    Hi Everyone,
    Have been watching the forum for a while but though i would post my first thread.
    Just wondering what vinyl & app tape people use for a glass shop window display?
    We recently did one using Avery 500 series and wet applied it, this caused us problems as many of the letters lost their adhesion?
    Any help is much appreciated.
    Edd
    Chris Windebank replied 13 years, 11 months ago 4 Members · 4 Replies
  • Peter Dee
    10 November 2011 at 09:37
    There’s your problem – you did it wet.
    10 November 2011 at 11:40
    quote Peter Dee:
    exactly!
    i wont harp on about wet v’s dry again, but it is a fact that dry is the superior method of application. once the vinyl is in position, thats were all the advantages of applying wet stop, and disadvantages start.
    applying wet is done purely to "aid the applicator" it is not recommended as method of application by the manufacturers.
    at the end of the day you must use whet ever method it takes to get the job doen 100% correct, we have to make a living at the end of the day…
    but for me, ide still body-swerve doing it wet,
    maybe try the new air release adhesive systems now available in etch vinyl.
    p.s. applying wet in cold weather on cold glass will add to your problems.
    if you must apply wet, use rapid tack.
    see video below for cold temp applications
    <embed width=”630″ height=”503″ quality=”high” bgcolor=”#000000″ wmode=”transparent” name=”main” id=”main” allowfullscreen=”false” src=”http://www.isigntube.com/player/vPlayer.swf?f=http://www.isigntube.com/player/vConfig_embed.php?vkey=f506af761d2277d853a9″ type=”application/x-shockwave-flash”>
  • Edward Thompson
    10 November 2011 at 15:15
    Hi Folks,
    Cheers for the replies.
    I have had another go at some of the window display with no spray, it goes on nice and smooth with no app tape.
    However there are lots of what look like bubbles under the vinyl when applied?
    Can understand why as the window was clean, dry and the vinyl was nice and taught when applied?
  • Chris Windebank
    10 November 2011 at 16:57
    tape up the graphic, then cut into sections you can handle. Apply graphic with a new squeegee and use the 45 degree method. Sure there are some posts on this. Once mastered you will do it on all applications with bubble free results
