Home › Forums › Sign Making Discussions › Vinyl › Vinyl advice, suitable for stickers on polypropylene bins
Posted by Neil English on 30 June 2010 at 08:50Hello,
Would anyone be able to recommend, a suitable vinyl, to produce printed stickers applied externally to textured polypropylene bins?
Thanks in advance.
Neil 🙂
Neil English replied 15 years, 4 months ago 6 Members · 11 Replies -
Either Hexis VCR3000WG1 or LG LD3888 G (from APS). Both are ultra high tack for
use on difficult substrates, and both are 4 year monomeric. Hexis do polymeric and cast
versions too, but they are expensive, and probably over specced for bins. -
Hi Neil,
We use a product supplied by Amari,
Arlon DPF 8000
Great product for exactly that use.
Adam. -
Thanks Jamie and Adam, I will try and get some samples, and do some tests. 🙂
quote Neil Davey:Hi Neil, we use Avery 4900QM.
Hello Neil,
Would like to test this Avery 4900QM vinyl, but am having trouble sourcing a sample, have tried Robert Horne with no luck and they say Avery wont supply any samples!
Any idea where I might get a sample?
Thankyou
Neil
Hi Neil,
I get mine from Spandex.Or PM me your address and I’ll pop a measly little bit in the post to you. 😀
That would be great Neil!
Unfortunately I cant PM you. would you be able to email me? would be greatly appreciated.
Thankyou
Neil
tut tut…Thought no email on the forum!!!??
But yes Spandex will/should give you a sample
Matt
I’ve done nearly 3000 stickers onto wheelie bins going into the olympics using LG3888 & standard laminate with no problems to date. In the process of running 2 rolls at the moment. Found the LG vinyl to have a more agressive glue than the Hexis version. LG glue gets very aggressive with high temperature like what we have at the moment
quote Matty Goodwin:tut tut…Thought no email on the forum!!!??
Matt
Oops! sorry I didnt realise.
quote Kevin Flowers:I’ve done nearly 3000 stickers onto wheelie bins going into the olympics using LG3888 & standard laminate with no problems to date. In the process of running 2 rolls at the moment. Found the LG vinyl to have a more agressive glue than the Hexis version. LG glue gets very aggressive with high temperature like what we have at the moment
Thanks Kev, I will look into it
