Home Forums Sign Making Discussions Neon, LED, Lighting views on LED illuminated sign needed?
  • views on LED illuminated sign needed?
    Posted by John Hughes on 17 September 2012 at 19:55
    Hi. We have been asked today to supply some 10mm clear perspex to be fitted in a new restaurant. The electrician will supply strip, colour change, LEDs to run along the top edge to ‘flood’ the panel with light.
    My question….is it as simple as that ?
    Can we supply standard clear Perspex and flood coat the rear (they may what a logo printed on the reverse as well) or is there more to this ?
    Sam Armstrong replied 13 years, 2 months ago 3 Members · 3 Replies
    17 September 2012 at 20:42
    lots of variables to take into consideration. ide say your main one is how bright/quality of LED’s used. the depth/drop these LED’s have to illuminate.
    you then have, how dark is the prints etc a strip of LED’s along the top only… 🙄 i doubt will work. obviously im just guessing and doing this blind, but still.
  • John Hughes
    18 September 2012 at 09:28
    Thanks Rob.
    Just rang Applelec for a price on LED light panels which would be best if customer budget allows.
    Still would like to know if anybody has achieved similar just with an LED strip though.
  • Sam Armstrong
    19 September 2012 at 14:18
    Hi, I have had a quick look at your enquiry to all. It actually sounds like an edgelit kit required. As with any LEDs the light will only travel so far so the size of panel is very important. The graphics can also make a vast difference as dark colours absorb the light. Often people get asked to engrave into the panel which can be very effective.
    Another factor is the location of the sign, if for example is in a room full of spot lights this may also not help with the general illumination of the sign or with a fluorescent lamp above also.
    Hope this helps in someway.
    Sam
