Home Forums Sign Making Discussions General Sign Topics vhb padded tape supplier
  • vhb padded tape supplier
    Posted by Cheryl Smith on 17 February 2014 at 08:31
    Hi, I have a bit of a rough interior wall to stick some 10mm foamex too…It doesn’t need to hold wight as such as they are floor height but to have a good enough stick as to not fall forward…does anyone know of a good material/supplier of such???
    many thanks
    Cheryl
    Vic Adair replied 11 years, 10 months ago 4 Members · 6 Replies
  • Glenn Sharp
    17 February 2014 at 08:58
    Speak to Tecman Cheryl…I’m sure they’ll be able to help you
    http://www.tecmanuk.com/
  • David Rogers
    17 February 2014 at 09:10
    On rough wall Cheryl I have been known to fix a flat sheet of thinner PVC or composite to the wall first with screws then tape / bond the main / front sign to that. Zero visible fixings and ultra secure. Doesn’t need to be ‘amazing’ VHB tape either as it’s two flat, glossy surfaces.
  • Cheryl Smith
    17 February 2014 at 09:15
    What I mean by rough…it has had signs fitted before with tape then ripped off leaving a bit of a mess of the chip board behind…so just to cover that over really…thanks for the tips…I will investigate further chaps 🙂
  • Glenn Sharp
    17 February 2014 at 10:54
    would velcro do the job Cheryl or do you need something more permanant ?
  • Cheryl Smith
    17 February 2014 at 12:02
    quote Glenn Sharp:
    Velcro could do the job Glenn if it was upto much…they would probably need these changing at some point…they are going to be low level in a squash court and the boards would probably be bashed a bit…
  • Vic Adair
    17 February 2014 at 12:48
    3M VHB tape
    http://www.vikingtapes.co.uk/c-324-3m-v … wIEgIXFejY
