Home Forums Printing Discussions General Printing Topics Verscamm cut issues
  • Verscamm cut issues
    Posted by Ryan Fairweather on 23 August 2006 at 10:24
    When i print and cut, although the cut pressure is sufficient it never seems to cut accurately.
    Examples are: cutting a rectangle, does not seem to cut cleanly into the right angle so when i attempt to weed it takes the decal with it.
    Cutting an oval, leaves a visible cut gap on two sides so i have to manually join the cut so that i can weed!
    Has anyone else experienced the same problems or have any solutions for me please?
    cheers people[/b]
    Ryan Fairweather replied 19 years, 3 months ago 8 Members · 9 Replies
  • 9 Replies
  • Nick Minall
    23 August 2006 at 10:31
    I dont have a Verscamm but sounds like the blade offset maybe wrong to me.
  • Cheryl Tissington
    23 August 2006 at 10:34
    Ryan,
    I’ve noticed the same thing when cutting ovals. Its as though the contour cut line isn’t closed.
    Cheryl
  • Rodney Gold
    23 August 2006 at 14:34
    Check the blade holder for freedom in rotation or change it , the metal one is the best , apart from that , check your cutting strip , if its not totally smooth or if its scored , change it.
    23 August 2006 at 16:01
    check as rodney says.
    also i have had these problems and cured them the lg print material weeds very poorly and makes you think something is wrong with the machine another make and its fine. the oval not quite closing could be the knife is facing the wrong way on entry to the vinyl on multiple cuts it quite often the first decal is poor closing the rest are fine cos the knife is now in alignment with direction this can be helped by using the smaller blade.
  • Steve Radford
    23 August 2006 at 16:10
    We had this when we got the machine. I cut a circle and it was all cut perfect, except for 1 small bit. Our problem was down to a setting on exporting our eps files, I believe it wasn’t leaving enough margin?
    When the engineer came in for training he changed it to be correct, but I can’t remember what he changed. Ours was a software issue, not hardware.
  • lulu51
    26 August 2006 at 10:01
    sorry, my English is very bad
    The parameters files should be modified
    because a file eps does not know its size
    Lucien
  • Steve Radford
    26 August 2006 at 10:53
    That’s the bit he changed 😀
  • Mondo
    27 September 2006 at 20:16
    Thank you, your English is fine. your communication skills are excellent!
    that just helped me as well.
    Dan Praught
  • Ryan Fairweather
    28 September 2006 at 09:13
    thanks for that. I will give it a go.
    merci
