Home Forums Vinyl Cutter Discussions Roland Cutters versaworks taking an age to open??
  • versaworks taking an age to open??
    Posted by Dan Osterbery on 15 April 2010 at 14:27
    Hi Guys,
    anyone had this problem before? It is taking versaworks about 8 hours to open? nothing has been changed one day to the next?? just thought id ask before i start re-installing?
    Kevin Flowers replied 15 years, 7 months ago 5 Members · 10 Replies
  • 10 Replies
  • Gary Birch
    15 April 2010 at 15:43
    Dan
    Sorry if I am trying to teach you how to suck eggs but if you have a rake of jobs in it it increases the time to load.
    Other than that sorry I can’t help mate.
    Gary
  • Martin Armitage
    15 April 2010 at 16:01
    Yep had this, never could work out why, I waited for it to open then cleared out the job list, which helped with the loading time, after about 3 weeks for some reason it cleared it self and started opening as normal
    Mart
  • Dan Osterbery
    15 April 2010 at 17:14
    Hi gary,
    have tried that! which is why i posted that other thread! I think i have a problem as i could not export or even save the previous jobs?? But even with the job list deleted we are taking an absolute age to open?? I dont think it has automatically updated itself! Will try re-install!
    Martin, you did nothing and it righted itself? how bizarre! Might leave it another few days before re-install!!
    Thanks guys!
    regards
    Dan
  • Kevin Flowers
    15 April 2010 at 18:38
    Dan
    don’t uninstall it go to the start men and initialize in this will clear you settings & jobs but cures a lot of problems basically resets everything you can also clear your job logs from there as well
  • Martin Armitage
    17 April 2010 at 08:28
    When I had the problem, I initialised wich reset versaworks, I then needed the ip address of the versacamm, to set up the printer – it also for some bizarre reason made the job list images unviewable.
    A couple of weeks later the program started running at normal speed, a little while later the images in the job list reappeared, no prblems since then
  • Kev Cringle
    17 April 2010 at 09:57
    Hi dan
    i had a similar problem with signlab 8 and it turned out to be anti virus that was slowing things down, also sounds like maybe some sort of auto update on the pc if other people have the problem then it cleared a couple of weeks later ? Just a thought but im no techno on pc’s just a thought ?
  • Dan Osterbery
    17 April 2010 at 13:32
    Hi guys,
    please elaborate on the process of the initialize process and i’ll give that a go! thansk for all your responses
    Dan
  • Kevin Flowers
    17 April 2010 at 14:56
    Dan
    Go to Start > programs > Versaworks > Initialize, was going to post screen capture but can’t here if you get stuck give me a shout
  • Dan Osterbery
    17 April 2010 at 15:02
    thanks kev, if i do this will i lose the rml files for the profiles that i have imported?? Does this basically reset to factory settings??
    thanks
    Dan
  • Kevin Flowers
    17 April 2010 at 20:48
    Dan
    yes i believe it resets to Factory
