Home Forums Printing Discussions Roland Printers Versaworks not recognizing cut path. pls help?
  • Versaworks not recognizing cut path. pls help?
    Posted by Ernest Seyram on 25 June 2012 at 10:26
    Hello friends,
    Just this friday, my versaworks won’t recognize the cut path on any eps file l send. Am working from coreldraw and illustrator. l use hairline for all print n
    cut, l have unintall versaworks and reinstall to the latest version 4.6 but still
    no joy, please any ideas?
    Ernest Seyram replied 13 years, 5 months ago 4 Members · 6 Replies
    25 June 2012 at 11:47
    In Wasatch (which I think is related to versaworks) you have to have the "Process cutting paths" box checked when you open the file otherwise it does not recognise the cut path. Versaworks may be the same?
  • HarveyShaw
    25 June 2012 at 13:00
    Few things to try
    flatten transparency
    if there is an imported photoshop image, it should have been flattened in photoshop fiest
    try just the cut line on its own see if that works, and if it gives the marching ants
    then the rest of the file is the problem
    rasterize the file, then put the cutline back on
    is the cut path correctly named : CutPath and is it a spot colour
    try saving as a pdf
  • Kevin Flowers
    25 June 2012 at 13:08
    as well as using hairline it must also be correctly named "CutContour", you can double click on either file icon A/B on the VW home page which allows you into default settings. Go to cutting page and tick check "Cut all Paths" this will then cut all stroke paths which is a pain if you have strokes in your design but does not need the path to be called CutContour
    Hope this helps
  • Ernest Seyram
    25 June 2012 at 16:29
    thanks friends,
    Kevin, the outline is correctly named "CutContour" with spot color and
    l’ve been using this for three years now, not a single problem like this.
    I tried to open versaworks as admin and its works, marching ants appeared
    but if l open versaworks the normal way it goes off again, weird.. any ideas
    so far?
    25 June 2012 at 19:25
    I think you may have deselected "process cutting paths". Make sure this is selected before you open the file
  • Ernest Seyram
    26 June 2012 at 10:52
    All solved, thanks guys.
    I sorted it by reinstalling Versaworks as admin.
