Home › Forums › Printing Discussions › Roland Printers › versaworks cut problem
Posted by Chris Windebank on 30 November 2013 at 11:21never seen this one before, printed labels yesterday and left to dry, went to contour cut and does not recognise rear registration marks.
Any suggestions?
Chris Windebank replied 12 years ago 3 Members · 9 Replies -
bit of a sod on a saturday
how long is the total length to find
just printed and cut all in one no problems to get me out of a hole. Would prefert o use the dried labels though
granny sucking eggs
not straight
mat laminate (my latest problem after changing make)
too glossy air bubble on the mark
sun shinning on the machine
sending wrong file ??? -
no laminate, no sun. Correct file. Will do a complete new and see if that helps.
bugger!
must admit i have had 2 complete failures in the last 24 months never got to find the reason
could try placing the good print and cut over the bad with a light box see if that shows up anything
hmmmm, printed, took out, replaced and cut
Seems it was just a blip
will do another and cut Monday
Thanks for your help Chris
quote Chris Windebank:no laminate, no sun. Correct file. Will do a complete new and see if that helps.
bugger!
Pinch roller in line with optical mark? We’ve had this – machine cant sense the mark if the pinch wheel gets in the way.
Andy
Cheers Andy, still got the print here will nudge it over a bit
