Home Forums Sign Making Discussions General Sign Topics Versaworks – Adobe Illustrator CS4 cut path problem ??
  • Versaworks – Adobe Illustrator CS4 cut path problem ??
    Posted by Shaun Cleary on 5 February 2010 at 15:34
    When I put a box (Cut path) around my artwork in adobe illustrator, sometimes versaworks only shows 3 sides with the moving line.
    This means it only cuts 3 sides of a square.
    Does anyone have any idea why this is ??
    Shaun Cleary replied 15 years, 10 months ago 3 Members · 6 Replies
  • Mathew Gibson
    5 February 2010 at 15:39
    Make sure all of you artwork is inside the perimeters of the artboard 😀
  • Shaun Cleary
    5 February 2010 at 15:53
    I have tried that,
    (1) Brought artwork in from customers PDF
    Box comes up This file contains text that was created in a previous version of illustrator.
    This legacy text must be updated before you can edit it.
    Choose update to update all of the legacy text now.
    I then press update.
    I have also tried sending this straight to Photoshop.
    I tried flattening it and making it in to a Jpeg or new PDF and then opening it up in illustrator, both still don’t work.
    (2) Art board is big enough for artwork
    (3) Put cut line around artwork 1 point stroke
    (4) Open in Versaworks only 3 sides have cut path
    I have tried a different jpeg this way and EPS file and both are fine.
  • OwenTaylor
    5 February 2010 at 16:03
    That’s happened a few times to me, once I was cutting a hundred decals and it decided to cut 3 sides on a random selection of the stickers. Here’s how I fixed it:
    edit – adjust the queue a/b settings before you load up the job. I just tried and it was greyed out when the job was already uploaded.
    Go to queue a or b job settings (whichever you are using). Under the ‘file format’ tab the top box is for the EPS margin settings. Add a margin of 0.5mm and your cutlines should appear. I think the margin has to be above 0.35mm or it won’t work so I just use 0.5mm.
    Hope that helps!
  • Shaun Cleary
    6 February 2010 at 10:11
    Tried all of that with no luck all other files work but this one.
  • OwenTaylor
    6 February 2010 at 12:28
    Can you attach the file – I’ll give it a try in Versaworks
  • Shaun Cleary
    6 February 2010 at 20:11
    Do you know how to attach a file on to this post.
