Home Forums Printing Discussions General Printing Topics Versaworks accidently deleted file can i retrieve it?
  • Versaworks accidently deleted file can i retrieve it?
    Posted by Jean Oakley on 15 April 2021 at 15:12
    Hi all rushing through cutting a lot of laminated prints and thought id done the lot. just found another set lurking in the corner having just deleted the job. It was two jobs compounded on one run so its not like i could reinstall the job accurately. I can hand cut but its around 40 small stickers and a few A4s. Can i undo or go into history (if there is one) and bring the job back?
    Jean Oakley replied 4 years, 8 months ago 3 Members · 4 Replies
  • Glenn Sharp
    15 April 2021 at 20:43
    Jean – there is a job log in one of the headings across the top
    I think it might be in VIEW
    I’m not certain of the functionality of the log but I presume you can retrieve printed jobs from there
    • David Stevenson
      15 April 2021 at 23:25
      Hi Glenn, Job log unfortunately hasn’t that feature. Only tells you when jobs start, stop & how much media & ink is used which is a shame 🙁
  • David Stevenson
    15 April 2021 at 23:23
    Sorry Jean but that’s a goner. Once you delete something in Versaworks there’s no way to bring it back. We’ve tried to get into a habit of saving any job (2nd option , including source file) that needs cut at a future date. It also helps to set the presets for your queues with a fixed width & spacing in the event you need to reload your job. We’ve ours set for 99% of jobs to 1300mm wide with a 15mm space. There’s always that day you forget to save and hit delete 🙁
  • Jean Oakley
    16 April 2021 at 11:42
    Hi all, I went to cut by hand and then remembered the A5s had radius corners 😣. I had nothing to loose so reloaded the two jobs and measuring the overall length and reset it. I used cut only and and amazingly managed to cut all the A5s correctly spaced. The smaller stickers which were only on there to fill up the job were not cut correctly but yes i just need to slow down and be more mindful of what I’m doing. Thanks for all the input was worth asking for another time but guess just need to get it right first time.
