Home Forums Vinyl Cutter Discussions Roland Cutters Versawork Cut lines.
  • Versawork Cut lines.
    Posted by John Mackenzie on 14 November 2013 at 14:14
    For some reason the cutline isn’t being recognised in versaworks, is there a quick fix as this job needs to be cut within the next 30 mins!!!
    NeilFox replied 12 years, 1 month ago 2 Members · 2 Replies
  • Nick Minnery
    14 November 2013 at 14:49
    Just checking John, try exporting it to Versaworks in a different file type.
  • NeilFox
    15 November 2013 at 16:23
    Has the artwork been done in Illustrator?
    If so, it could be the transparency layers.
    My work round is to select the layers with the transparency layer that is causing the problem (or select everything except the contour cut line) and rasterize it at 150bpi.
    Then send to VersaWorks again and should work fine.
    Neil
