Home Forums Software Discussions General Software Topics versawork 5 advice
  • David Stevenson
    6 December 2021 at 23:41
    Hi Lynn, this image is from VW6 but it should be in the same location in VW5. Simply change the page space to 0mm for no gap. Personally I wouldn’t recommend this. I know over time it adds up to some wasted material but it provides you with a much needed break in the event you’ve a problem with your laminator or are about to run out of laminate. Today for example when laminating a large roll of material for a van wrap I was able to use the remains of 3 rolls instead of having to open a new roll. Had I had no gaps these 3 rolls would have lay in the corner un-used. They’d a combined value of approx £100 so worth using up.
  • Lynn Wang
    8 December 2021 at 16:46
    <div>thanks , David Stevenson</div><div>
    i set as below ,
    https://photos.app.goo.gl/s7w63XkAG8RG4hUD8
    but it is still same , big gap between jobs
    thanks
    </div>
