Versacamm / Versaworks eps problems….
Hi Guy & Gals,
Having a bit of a problem with versaworks and using eps files to print.
Export from Corel x4 in eps, postscript level 3 and when I try to rip these Versaworks crashes.
Its ok with previously used eps files just cant get it to run anything new I do
No problems if I use JPG’s
Havent used the machine for a while and the only change was the software update to v4.20.
Am I missing / forgetting some little trick here?
Hopefully someone can help.
Thanks in advance
Nigel
