Home Forums Printing Discussions Roland Printers Versacamm stuck at now processing – help please?
  • Versacamm stuck at now processing – help please?
    Posted by David N Foster on 25 November 2014 at 18:49
    Hi everyone, hope someone can help. We have printed some text with a gradient fill and a ccutline applied in corel x5. Our versacamm sp540 prints it no problem with the alignment marks. The problem is after lamination. I have reloaded the media, changed the cut setting to cut only and then when i press cut the printer says now processing and makes a noise like its about to start cutting then just stops abrubtly and goes back to the screen showing the media width. The printer head doesnt move or do anything at all. We have been at this all afternoon trying to figure out whats wrong and we have no clue. Does anyone have any ideas? Many thanks
    Martin Oxenham replied 11 years, 1 month ago 5 Members · 6 Replies
    25 November 2014 at 18:55
    Try re-booting your computer.
  • David N Foster
    25 November 2014 at 19:01
    Hi phill, yeah ive tried that, to no avail 🙁
  • Dan Finn
    26 November 2014 at 07:24
    Had the same problem intermittantly, my workaround is to load the original .eps file into versaworks again as though starting from scratch, set the same parameters as the first one for crop marks, number of copies etc, then select cut only and go. Should do the trick.
  • Lee Reeves
    26 November 2014 at 07:26
    We had a very similar problem with our XR640 it ended up being a button stuck down on the printer keypad.
    I hope it’s as simple as that for you too
  • David N Foster
    26 November 2014 at 07:28
    Hi dan, ill try that when i get into work this morning. You would think they would make things a bit simpler lol
  • Martin Oxenham
    26 November 2014 at 14:28
    We get this quit often, don’t know why. Just turn the printer right off and restart.
