Home Forums Printing Discussions Roland Printers Versacamm SP300 stalled after printing
  • Versacamm SP300 stalled after printing
    Posted by Peter Dee on 21 September 2011 at 14:58
    I’m using SL9 with Visual Production Manager (XP Pro) and sent a print/cut job to the SP300. It finished printing a 3m run, wound back to the start ready to do the contour cutting and just stopped.
    Looking at VPM it still says printing – 80% done and I can’t access the job (hourglass). I did a smaller version no problem but this 3 metre run seems to have a problem. It was set to print then cut straight away.
    In Windows Task Manager it shows VPM as not responding and under "processes" PSQueue.exe as 50% processor use.
    I’ve now shut down VPM and re-sent the job and selected cut only.
    Luckily I hadn’t moved the print from its origin so the contour cutting still lined up. Got to do a second one and would like to know why this happened.
    Any ideas?
    Peter Dee replied 14 years ago 2 Members · 2 Replies
  • Kevin Flowers
    21 September 2011 at 15:32
    there is normally a maximum print & cut length, don’t know about the software you are using. Versaworks accepts the file, prints it but then wont cut it.
  • Peter Dee
    21 September 2011 at 16:23
    Pleased to say I’ve done the 2nd run OK.
    Only difference was I turned off Kaspersky protection as when I start a print job it flashes up that it has allowed PSQueue.exe and my thought was that as the queue progressed to cutting Kaspersky may put a slight hold on it whilst checking, and cause it to stall.
