Home Forums Printing Discussions General Printing Topics VERSACAMM PRINTING ON CONVEX VINYL
  • VERSACAMM PRINTING ON CONVEX VINYL
    Posted by Lee Westoe on 22 February 2007 at 11:15
    CAN ANYONE HELP ME!
    I HAVE A VERSACAMM 300 AND RECENTLY PURCHASED CONVEX MATT WHITE VINYL FROM AMERICA, TO PRINT MOTORBIKE DECALS. I HAVE A PROBLEM PRINTING BRIGHT COLOURS. CAN ANYONE OUT THERE RECOMMEND WHICH RIP/PROFILE TO GET THE BEST RESULTS OR ANY SUGGESTIONS
    THANKS LEE
    Chris Wool replied 18 years, 10 months ago 6 Members · 16 Replies
  • 16 Replies
  • Peter Shaw
    22 February 2007 at 18:30
    Why did you buy vinyl without the appropriate profile for your RIP?
    That’s your problem.
  • Lee Westoe
    22 February 2007 at 19:08
    I HAD A PROBLEM WITH SOME BIKE DECALS ON PLASTIC TANKS, WHERE THE PETROL FUMES WERE REACTING WITH THE MATERIAL AND MAKING IT BUBBLE UP. AFTER TRYING 3M, ARLON AND MANY OTHER MANUFACTURES,I FOUND THAT CONVEX HIGH BOND MATT WHITE WAS BEST FOR THESE DECALS. I FOUND A PROFILE WHICH WAS PRETTY GOOD SO WENT AHEAD AND PURCHASED THE ROLL OF VINYL AND LAMINATE. WENT OK UNTIL I HAD TO PRINT GREEN, I JUST CAN’T GET A BRIGHT GREEN NO MATTER WHAT I TRY.
  • Peter Shaw
    22 February 2007 at 19:46
    You could try going back to Convex to see if they have a profile for your RIP/printer.
  • Matt Boyd
    22 February 2007 at 20:00
    LEE<
    PLASTIC GAS TANKS ALLOW FUMES TO PASS THROUGH, WHICH CHEMICALLY REACT WITH THE ADHESIVE ON THE VINYL. YOU MAY NEED TO CUT SLITS INTO THE DECALS TO ALLOW THE PLASTIC TANK TO BREATH/FUMES TO ESCAPE. THIS STILL MAY NOT STOP THE BUBBLING EFFECT THE FUMES WILL PRODUCE THOUGH! WHAT YOU NEED TO DO IS FULLY CLEAN THE AREA WHERE THE GRAPHIC IS BEING APPLIED AND SEAL THE TANK WITH A CLEAR COAT, WE RECOMMEND LEAVING THIS FOR AROUND 3 DAYS. SHOULD CURE MOST PROBLEMS. THIS IS WHAT WE TELL ALL OUR CUSTOMERS, JUST DOWN TO EXPERIENCE!
    MATT
  • Lee Westoe
    22 February 2007 at 20:07
    I HAVE CONTACTED CONVEX AND THERE SEEMS TO BE NO PARTICULAR PROFILE. THERE MUST BE SOMEONE OUT THERE WHO CAN HELP WITH THIS PROBLEM.
  • Matt Boyd
    22 February 2007 at 20:16
    Lee, were just about to order some convex, never tried it before, is it very comfortable to use? and it is a nice thickness with the laminate?
    cheers,
    matt
  • Lee Westoe
    22 February 2007 at 21:21
    I APPLIED THE DECALS IN A COLD GARAGE AND DID NOT EVEN HAVE TO USE A HEAT GUN. HAVE TESTED ON PLASTIC TANKS WITH 6MIL AND 12MIL LAMINATE FOUND BOTH GREAT .THE ONLY THING IS WITH THE 12MIL YOU HAVE TO CUT AROUND THEM TWICE WITH TWO CONTOUR CUTS WITH THE VERSACAMM, SO I HAVE WENT WITH THE 6MIL AND FOUND IT GREAT, APART FROM THIS PROBLEM WITH THE PROFILE, WHICH I STILL HOPE SOMEONE CAN HELP ME WITH
    THANX LEE
  • Matt Boyd
    22 February 2007 at 21:31
    so the convex forms nicely over the bikes plastics etc? its nice and comfortable to work with then? sorry can’t help you with the rip issue, but i’m sure someone will be able to help on here.
    cheers,
    matt
  • Jason Xuereb
    23 February 2007 at 14:24
    In terms of cutting twice for the 12mil have you adjusted your blade depth correctly? Seems like cutting twice and it being fine for the 6 that you havent adjusted the blade for the thicker laminate.
  • Lee Westoe
    23 February 2007 at 14:38
    CUTTING IS NOT A PROBLEM YOU COULD GET THROUGH THE 12MIL WITH A 60 DEGREE BLADE BUT DID NOT FIND IT NECESSARY. ALL I NEED TO KNOW IS THERE ANY VERSACAMM PROFILE FOR CONVEX MATERIAL, WHICH WILL PRINT BRIGHT COLOURS.
  • Stephen Morriss
    28 February 2007 at 15:31
    Greens and orange on the versacamm are very hard to get, it’s to do with the 4 colours or something, someone on this group said they got better results with colours printing directly from Corel though, but that doesn’t help with print laminate and cut.
  • Peter Shaw
    28 February 2007 at 18:43
    Steve,
    quote :
    I disagree. I have no problem printing green and orange on my Cadet both with the activasol ink and now the Ecosol Max inks I have moved to.
    I recently produced a couple of prints for a regular customer with orange in their logo and was able to be pretty close to the pantone colour. I also did a light box for an Indian takeaway last week with a vivid green printed onto translucent vinyl.
    I still think the problem lies in the profile.
  • Stephen Morriss
    28 February 2007 at 19:13
    I can get greens and oranges Peter but the really bright vivid ones are hard to get, I’m using the uniform profiles on uniform media with uniform inks.
    Kawasaki green is hard to get as well as ktm orange and the orange on Repsol stickers, however I can get a lot of the pantone colours.
    Indeed they are very close just using Corels pantone pallet and export as eps.
    I think these vivid colours have something else in there to enhance the colour similar to day-glow colours
    1 March 2007 at 00:38
    steve i cant remember where i got them from but was a set of cmyk colour charts for you to print with use different profiles on to different media next time you are trying to make a colour the info is there.
  • Stephen Morriss
    1 March 2007 at 09:46
    Yes I already have these Chris.
    My initial post was to point out to Lee that some colours are very hard to get, some are impossible.
    Motorcycle graphics quite often use very bright colours which I’m sure have some sort of enhancement to the brightness, this makes it hard to match with a CMYK printer.
    Indeed I think it was Shane Drew who recently had his printer converted to use orange and green inks to get round this problem.
    1 March 2007 at 15:11
    allprint have a cracking set of profiles for max inks
    try 100 y 75 c 0m 0k kwaka green.
