Home Forums Printing Discussions Roland Printers Versacamm Print Sizing Problem
  • Versacamm Print Sizing Problem
    Posted by Kevin Talbot on 26 March 2009 at 21:41
    Can anybody point me in the right direction please, I send file to versaworks and size the job there as I always have, but for some reason i am sizing some numbers at 150mm high but they print at 130mm high they are also narrower than they should be, I have never noticed this problem before and am wondering if it has anything to do with installing the new free software, any help would be appreciated. Thanks Kevin
    Kevin Talbot replied 16 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Kevin Flowers
    26 March 2009 at 22:38
    Kevin
    silly question but is the scale set to 100%
  • Kevin Talbot
    26 March 2009 at 23:11
    Posted: Thu Mar 26, 2009 11:38 pm Post subject:
    Kevin
    Yes 100 %
  • Jason Xuereb
    26 March 2009 at 23:13
    Is your font converted to outlines? What file format are you saving in? Have you tried another format?
    What version of versaworks?
  • Kevin Talbot
    27 March 2009 at 08:35
    Have converted font to outlines. File format ESP. No.
    The image that I am trying to print and cut is numbers for basket ball shirts and we have previously done these and want some more we do have some of the originals to compare its just when we set the size if image in versaworks ie 150mm high it actually prints/cuts 130mm high, for some reason it seems that it is only these images as i have just created a basic box sent it across to versaworks set to 150mm high, printed and hey presto printed box 150mm high. i realise that I can set the size of required numbers higher to achieve my 150mm high but i would like to understand why this is happening. Thanks Kevin
  • Dan Osterbery
    27 March 2009 at 09:36
    does the font have a stroke on it that is not being picked up??
    regards
    Dan
  • Ryan
    31 March 2009 at 21:26
    have you tried saving files in different format eps/pdf etc? Also, have you tried checking the file in outline mode on AI maybe there is an ealier stroke hidden that is cutting it short?
  • Simon.James
    31 March 2009 at 21:44
    Hi Kev
    What file format are you sending it down, I use versa works and shiraz, versaworks is a great software but does some strange things with pdf’s now and again. shiraz has never ever thrown up a pdf problem in 3 years of ownership.
    whether its a pdf or an eps. try saving out as a quality maximum jpeg. and send that down. if that dont work, I suspect your file maybe wrong?
    Simon
  • Kevin Talbot
    31 March 2009 at 21:52
    Thanks for every bodies input, after alot of playing around I could not get this image to work for me so I did give up and redesigned it, it was definitely the image and not the machine. Thanks once again. Kevin
