Home Forums Vinyl Cutter Discussions Roland Cutters versacamm pressure lines from wheels appearing in print
  • versacamm pressure lines from wheels appearing in print
    Posted by Dan Osterbery on 15 September 2011 at 09:33
    Hi All,
    new problem this morning! we are printing canvas on the same canvas as normal and on the same profiles etc but we can now see the lines of the wheels in the print? Can anyone help in any way with this problem?
    Dan
    David Hammond replied 14 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
    15 September 2011 at 09:54
    I had a similar issue where I could see lines down the print from where the rollers had been. I gave them a quick clean and seemed to fix the problem.
  • Dan Osterbery
    15 September 2011 at 10:05
    thanks for the reply david! what did you clean them with alcohol, water?
    Dan
    15 September 2011 at 10:09
    I actually used the cleaning solution for the heads. However I am sure Meths or similar would suffice. I wouldn’t fancy putting water near my printer :lol1:
    Mine was on a VersaArt, not Versa Cam but can’t see it being a problem.
  • Dan Osterbery
    15 September 2011 at 10:13
    thanks will give that a shot!
  • Stafford Cox
    15 September 2011 at 13:14
    I’ve always used IPA (Isopropynol alcohol) for cleaning pinch rollers, going right back to my laser printer repairing days.
    Also check that the heater temps haven’t changed and that the media is stored in a place with a reasonable ambient temperature overnight. A lot of media/heat related problems aren’t necessarily due to the amount of heat you use but the sudden change of temperature. Apparently it deforms the adhesive or some nonsense like that… 🙄
    Good luck
    Stafford
  • Dan Osterbery
    15 September 2011 at 15:45
    thanks guys! tried alcohol first and that didnt work and then i got out the solvent ink cleaner that we use for servicing the machine and it has worked a treat! Did a quick clean as we had all the gunk out and it is now working perfectly again!
    thanks for all your help guys, much appreciated!
    Dan
    15 September 2011 at 15:46
    😀 Yay i’ve done some good 😀
    Always nice to return the favours.
