Home › Forums › Printing Discussions › General Printing Topics › Versacamm overspray
		Versacamm oversprayPosted by cw products on 6 March 2007 at 22:37Can anyone throw any light on this.
 I get a blue mist like overspray when I print black, I can print blue on its own and it is perfect.
 cheers chalkMartin Oxenham replied 18 years, 7 months ago 6 Members · 12 Replies
Are you printing black? 0.0.0.0
 sometimes it’s easy to pick "black" from your palette, but it may not be,Not much help am I? peter
i have had this before and put it down to static after using some film
 i earthed the film out to a water pipe momentarily by holding both
 i had heard some small cracking noise while printing which made me think of it.other possibility is the bi-direction or head calibration could be out because cyan is used to make black. chris
funny you say that about a cracking noise, I’ve got that as well. sounds like a spark
before I upgraded, thats why I did it, to see if it solved the problem
was printing fine until I put some clear film through to print onto, then found the overspray was bad, went back to my normal vinyl and it was still the same
thanks Chris. don’t no whats wrong can’t pm ya back.
 thanks again. colin
had this problem recently…turned out to be a tiny hair stuck to the black print head! once removed, back to normal…
I also have had this problem with a jv3. Although only on particular resolutions. The nozzle pattern was a bit wonky, so I changed the head and the problem went away. Now it’s occurring on the other colours… 😕 Static is an interesting thought. I just want to know how to get rid of static from the media – I thought perhaps an earth cable attached to a roller before the media hits the platen…
We use Anti-static tinsel draped over the vinyl.
 Seems to work.
