Home Forums Printing Discussions Roland Printers Versacamm not cutting corners on letters properly
  • Versacamm not cutting corners on letters properly
    Posted by Mo Gillis-Coates on 7 July 2011 at 13:02
    Guys, anyone sen anything like this? Regardless of blade I’m having a problem cutting small fonts (not really small about 30-40pt) I have done the fig of 8 thing but to no avail, I thought it was the cut in general but it seems to be just small corners, large types are fine although some corners are still a bit dodgy..
    anyone?
    BigMo
    Mo Gillis-Coates replied 14 years, 5 months ago 2 Members · 5 Replies
  • Chris Windebank
    7 July 2011 at 13:13
    have you changed the blade offset? If you buy blades from Xpres (are these harrys blades)? you might need to, only a thought Mo
  • Chris Windebank
    7 July 2011 at 13:18
    http://www.blades.uk.com/cutteroffset.html
    here is some info on the blades
  • Mo Gillis-Coates
    7 July 2011 at 13:31
    Hi, they are smart knives from xpres the ofset is 0.25 the same as it has always been, this never used to happen when I fist had the machine….. starting to get the hump now its costing me time and material
  • Chris Windebank
    7 July 2011 at 13:40
    give Harry a call, he makes the blades and knows these things inside out
    01928 739799
    He will sort you out Mo
  • Mo Gillis-Coates
    7 July 2011 at 13:49
    will do thanks chris
