Home Forums Printing Discussions General Printing Topics VersaCamm and Laminating Prints
  • VersaCamm and Laminating Prints
    Posted by Darrell Wootton on 25 April 2007 at 10:31
    Started working with our new Versacamm and I have been asked to do some graphics for a car (not a vehicle wrap just decals)
    Whats the best way to laminate for use on cars, I am a little worried about the laminate lifting off the print? What I considered was:
    Print – Cut – Remove Unused Vinyl From Around Print – Laminate – Cut Laminate (Leaving a oversized laminate edge of about 5mm beyond the print boundry)
    Using: VersaCamm, Versaworks, Coreldraw, Metamark MD5 and Metaguard Laminate.
    I would assume that I would need 2 cutlines one for each decal and an oversized one for the laminate?
    Has anyone done this and are there any pitfalls,
    Daz….
    Gavin MacMillan replied 18 years, 7 months ago 5 Members · 10 Replies
  • 10 Replies
  • Fred McLean
    25 April 2007 at 10:40
    Print/Laminate/Cut once only 😀
  • Darrell Wootton
    25 April 2007 at 10:57
    Fred,
    Are you saying cut the lamiante to the print size?
    Will it be OK and not lift off the print?
    Darrell…..
  • Fred McLean
    25 April 2007 at 11:04
    Once printed leave for a while to dry 😀 Laminate with whatever your using stick back in the machine and cut both layers at same time
    i think thats how the versa works 😀
    25 April 2007 at 11:29
    out of interest daz where did you buy this machine didn’t the dealer show you what the machine is capable off or how to use it.
  • Darrell Wootton
    25 April 2007 at 11:34
    Hi Chris,
    Yes was given a days training by Roland engineer on install and I have been doing some laminating as per the Roland guys instructions but I was just a little worried that the laminate might lift when washing car etc and wondered if anyone did it differently.
    Daz….
  • Gavin MacMillan
    25 April 2007 at 12:16
    I can’t get the print/lam/cut to work successfully at all and have had to look at other options 🙁
    Will be hassling them some more when I have time!
    25 April 2007 at 12:54
    quote :
    as long as you let the print dry first you should not have a problem
  • Darrell Wootton
    25 April 2007 at 13:04
    My 540 is fine works a treat at Print – Lam – Cut very impressed!
    Is it a Roland VersaCamm and what problem are you experiencing?
    Daz…..
  • Gert du Preez
    25 April 2007 at 16:47
    Do not make the laminate oversize. Just lam, and cut both together. The edges will not lift. Touch wood.
  • Gavin MacMillan
    25 April 2007 at 16:57
    I’ve posted here before about alignment issues when I print/lam/cut. Tried lots of different things but nothing has helped.
    G
