Home Forums Printing Discussions Roland Printers versacamm 300v heat problem
  • versacamm 300v heat problem
    Posted by Nick Williamson on 15 January 2009 at 15:13
    we run a roland vp300 now 18months old having problems when printing a solid black. It appears the ink is not drying so the heads seem to drag a nice black line across everything. Platten seems to be very hot one side and only warm the other any one else had to replace a heater element or thermostat any good engineers for rolands in the worthing/west sussex area ? any ideas welcomed.. cheers Nick
    Nick Williamson replied 16 years, 11 months ago 3 Members · 4 Replies
  • Richard Urquhart
    15 January 2009 at 19:16
    sounds like the head is touching the vinyl ?? got a picture? 😀
  • Nick Williamson
    16 January 2009 at 10:02
    Will post a piccey in a mo but more worried about the hot plate getting really hot one side and just warm ont tother cheers Nick
  • Mark Elvidge
    17 January 2009 at 10:54
    something dragging will more than likely be debris/fibres on the head.
    clean out the captops and have a good look around the heads for what might be just 1 strand of fibre.
  • Nick Williamson
    17 January 2009 at 11:53
    have cleaned the heads and all surrounding areas no fibers or hairs or such like think the vinyl was cold and the damp atmosphere doesn’t help matters but the hot end of the platten the ink is fine but as you progress towards the cooler end the ink seems thicker and the yellow letters on a solid black background go fuzzy so if the ink wasn’t dry and the vinyl puckered slightly I suppose the heads would drag across the surface ?
    just leaves the heat problem then ?
