Home Forums Printing Discussions Roland Printers Versacam printing quality problem
  • Versacam printing quality problem
    Posted by Matthew on 16 August 2009 at 11:30
    Hope someone can maybe help with a printing problem I am having with my Versacamm SP300.
    If for instance I am printing a square full color photo, the image does not print with completely straight edges. It will be perfect for say 3", but then there will be 1" where the print protrudes from the edge. It is as if the head is not resetting to the correct position, and then lays the ink in the wrong position. I am using the correct profiles and this happens on all types of media. it leaves areas of the print looking slightly blurred. Any advise would be a great help. Thanks in advance.
    Matthew replied 16 years, 4 months ago 3 Members · 3 Replies
  • George Zerbino
    16 August 2009 at 11:40
    Sounds as if your encoder strip is dirty and needs cleaning.
    16 August 2009 at 11:43
    sounds like the encoder strip has dirt on it.
    again
  • Matthew
    16 August 2009 at 11:45
    thanks for the quick responses, especially on a Sunday! I will give it a go and let you know. Thanks again
