Home Forums Printing Discussions Roland Printers versa camm vp colour problem
  • versa camm vp colour problem
    Posted by Nick Williamson on 12 August 2007 at 13:17
    Hi all nick here from sussex regards versa camm vp am I doing something stupid here or is it a roland thing. have printed off the roland colour chip sets and the default colours into corelx3 when we try to match the colour of the roland chart the printer does not always match the desired tone same settings and white vinyl as the colour chip
    also how do yo get a gold colour ? the roland one come out like beige or cream to the younger ones of you. yes its sunday and some of us are still working not sitting on the beach any suggestions on colour not the beach chheerrrrrs ?
    Nick Williamson replied 18 years, 4 months ago 3 Members · 3 Replies
  • Michael Antrum
    19 August 2007 at 08:40
    Hi Nick
    First of all the Roland Colour Library relies on what is often called ‘spot colour replacement’.
    Effectively the Roland Colour Library is a set of named spot colours and when the file is exported, the names of each colour used are exported in the file.
    When the rip loads up the file, it sees the names used in the file and matches them up to a specific CYMK value that is held in a table inside the RIP. It therefore bypasses the normal ICC profile system so you get an consistant repeatable colour when you print it.
    However, and a lot of people miss this, you must turn on this system in the RIP before it will work. You need to go to ‘EDIT – Queue A Settings’ and then to the File Format section. In here you have ‘named colour settings’ and ‘special colour settings’. Turning these on should solve your problem.
    With respect to achieving a decent gold colour, we need to think a little outside the box of what colour it should be. It needs to be more than one colour. When we look at something gold, we are looking at a metallic colour, and, as with all metallics, the colour changes with the angle of incidence and also reflection of the environment, etc. So the trick is not to use a single colour.
    To make a more convincing gold, use a linear graduated fill where the fill repeatedly changes from a darker gold yellow to a lighter gold yellow. Alternatively there are photoshop and SignLab plug-ins from Alien Skin called Eye Candy that can do this for you – but wil cost a few quid. However, a bit of experimentation with a linear graduated fill tool should so you right.
    Best Regards,
    Mike
  • Ian Bingham
    19 August 2007 at 11:07
    Morning Mike, (mod-edit)
    I had the same problem, thought it was just me, will try it in the moring
    Ian
  • Nick Williamson
    20 August 2007 at 09:01
    Thanks Michael will try to change the setting in edit a have had to do this before to allow (EPS margin 05mm) the outline cut to work on all surfaces
    was beginning to think no one had any suggestions there for a while,
    cheers nick
