Home Forums Sign Making Discussions General Sign Topics Velcro – Attaching a sign to material display boards
  • Velcro – Attaching a sign to material display boards
    Posted by Stacey Clinch on 6 July 2010 at 13:40
    Hiya
    Can anyone advise me on Velcro (on a roll)??
    I need to attach some 2mm foamboard (1m x 3m) to a material covered display board.
    I was going to use some 25mm Velcro strips to attach it as it is only going to be in place for 1 day.
    Can anyone advise me if this will be strong enough to keep it in position as I’ve never used Velcro on signs before….so not sure how much I will need to use.
    I’ve got 27 panels @ 1m x 3m to fit – would I be better sticking strips of 150mm along the edge of the board, or full strips??
    HELP!! I am completely clueless on this one!
    Stacey Clinch replied 15 years, 5 months ago 3 Members · 3 Replies
  • Fred McLean
    6 July 2010 at 14:39
    Stacey you might be best with large diameter velcro coins which you can get from UK point of sale i think (?)
    2mm foamex isn’t very heavy so depending on which diameter ones you get you might not need as much as you think and will give a better spread
    of contact rather than strips as the board will flex quite a bit.
    Hope that helps a wee bit.
    F
  • Kev Mayger
    6 July 2010 at 14:40
    3 vertical strips full length will do the job. You may need a couple of small tabs in between on the short edges to stop them from bowing out.
  • Stacey Clinch
    6 July 2010 at 20:14
    Hiya Guys
    Thanks for your advice – I’ll get some ordered tomorrow.
    THANK YOU.
    Stacey
