I use impact, and generally they are “acurate” (?) (terminator) but do not expect to cut a panel that will fit, I usually undersize everything for safety, especialy the rear of the van. Most off the corner radii are inacurate. If you need an exact fit on a panel a physical measurement is needed. As I work through different makes/models I modify the templates as required.
Please note:
