Home Forums Software Discussions General Software Topics Vehicle outline software
  • Vehicle outline software
    Posted by Mark T on 29 May 2004 at 12:32
    Hi everybody ,i have just bought a vehicle outline c.d. called mr clipart,
    i use signlab software but i cant seem to get on with it i.e it does not scale
    the outline to the size of the vehicle, any body know of a better outline software that does the outline to fulscale.
    chears
    Mark t
    Steve Maple replied 21 years, 6 months ago 4 Members · 4 Replies
  • Fat Bob
    29 May 2004 at 13:16
    Mark
    Mr Clipart will scale if you draw a box around everything go to node point right click mouse
    Go to size there should be two boxes one in pecentage change from 100% to 2000% this should makie it to full size
    Hope this helps …………FB
  • payads
    29 May 2004 at 14:03
    Hi Mark
    I use the 2003 version of Mrclipart
    To scale up to correct size use 1000% then 200% that will take it to the correct size of vehicle.
    Goodtip, the actual size is shown for each vehicle, once you’ve scaled it up, use your drawing tool in your software to draw a line the length of the vehicle, check it, should be the same as what is down on the template.
    You Normally get a 5 to 7 mill difference when scaling up.
    Good luck
    frank 🙂
  • Nobby Thomas
    29 May 2004 at 17:03
    Just a pity you did not speak to our Friend Brian first, could have saved yourself some money!!! 😥 😥
  • Steve Maple
    4 June 2004 at 11:17
    there is a wheel base dimension
    simply draw a thin box at this size and pull the
    drawing up to it!
    – then go check the wheel base!!!
