Home Forums Sign Making Discussions File Swapping vehicle outline help please!
    19 June 2006 at 08:35
    Hi ryan,
    if you bought your disc in the last year Brian will give you any updated vehicle outline you need free.
    I’m sure he’d happily help if he has this outline!
  • John Childs
    19 June 2006 at 10:53
    Can’t you just draw in the extra windows on a van outline?
  • Ryan Fairweather
    19 June 2006 at 10:58
    didn’t know if it was a simple case of replacing the panel behind the driver with a window or if the vehicle layout changed significantly?
  • David Rogers
    19 June 2006 at 11:03
    It should be practically identical to a Renault Trafic (if that’s any help) and maybe even the peugeot boxer IIRC.
    (Same body shells)
  • Ryan Fairweather
    19 June 2006 at 11:11
    trouble is that this manual doesnt seem to have the crew cab versions of those vehicles.
    I think i will go with the idea of replacing the panel with a window as thats usually what they do with these conversions.
    cheers guys and girls 😀
    Ryan
  • John Childs
    19 June 2006 at 11:45
    Ryan,
    Just have a poke about on the web, probably the Renault site, and find a picture to give you an idea of glass size and shape. I would be VERY surprised if it was a different bodyshell because I can’t see them going to all that trouble when slapping in a couple of bus version windows, which they already have in their parts box, would do the job just as well.
    Dave,
    The Vivaro and Trafic are the same shell, also the Nissan Primastar. The Boxer is something else altogether.
  • Ryan Fairweather
    19 June 2006 at 12:04
    cheers John,
    will do
