Home Forums Sign Making Discussions Vinyl Vehicle graphic lamination, advice needed please?
  • Vehicle graphic lamination, advice needed please?
    Posted by John Malone on 5 April 2014 at 09:49
    Hi all,
    I could do with a bit of advice, please.
    A local shopkeeper has asked me to do a set of signs for his shop with matching signs for his van.
    I’m going to laminate the shop signs, but I’m not sure about laminating the van signs. Should I, or will that make them too thick to apply properly?
    John Malone replied 11 years, 7 months ago 3 Members · 4 Replies
    5 April 2014 at 09:56
    If it’s digital print then you really must laminate them or they will only last short term. But if it’s self coloured vinyl there is no point in laminating them.
  • John Malone
    5 April 2014 at 10:02
    Thanks Rob. I should have said, it’s a print. So I’ll laminate.
    5 April 2014 at 10:07
    quote John Malone:
    Thanks Rob.
    Rob? :lol1:
    Phill is correct, unless very short term its always best to laminate the prints when applying to a vehicle. laminating vehicle prints enhances the print and help protect from abrasion, chemical and UV damage by the sun.
    it will actually make the application easier as it with thicken up the feel of the film so you wont need application tape unless the prints a contour cut odd shape or if you dont have a felt squeegee as a nylon one will create friction against the vinyl surface.
    best of luck…
  • John Malone
    5 April 2014 at 13:54
    Sorry, that should read Phil (but the email telling me there was a response was from Rob!)
    And thanks for the additional info, Rob.
