Home Forums Printing Discussions Mimaki Printers Valuejet 1204 error message
  • Valuejet 1204 error message
    Posted by Simon Duggan on 27 March 2012 at 12:20
    Hi People
    Anyone had the error E065 error pf motor message before and does it mean a new motor is needed if so anyone got an engineer near South Wales they can recommend
    Simon
    Stafford Cox replied 13 years, 8 months ago 3 Members · 3 Replies
  • John McNickle
    5 April 2012 at 16:56
    Mine is the same Simon, digiprint have them for near £200 i dont know if its a DIY job or not
  • Simon Duggan
    6 April 2012 at 08:11
    I read up a bit on the net and I think it is a sensor problem not a motor failure. I give the dock where the head stays a good clean and the error has stopped I still think mine needs a proper service though so when I locate an engineer will book one
  • Stafford Cox
    18 April 2012 at 10:21
    From the service manual:
    Abnormal condition in PF motor (X-axis) during printer operation. Displayed if the difference between motor command value and feedback from encoder is large.
    1. Check error history from "Test7: Record." of selfdiagnosis function.
    2. Set the number of endurance running cycles to 50 or more from “Check10: Endurance” of "Life2: PF Motor" of self-diagnosis function, and check if "X motor error" occurs.
    3. Check "Encoder: PF" from "Test5: Encoder" of selfdiagnosis function.
    4. PF motor assembly may be defective.
    5. Main board assembly may be defective.
    Stafford
