turn on half of the lamps. i.e. if you have 4 lamps, use two. half the heat so helps prevent it rising. you could also run a fast print setting so it has less time to rise.
You can also put a scan delay (pause per head pass) on the machine. This will help prevent the build up of heat and allow the material to ‘relax after each pass.
Please note:
