Home Forums Vinyl Cutter Discussions General Cutter topics Us cutter mh721 cutter issues
  • Us cutter mh721 cutter issues
    Posted by Treadsnsigns2017 on 23 July 2017 at 20:56
    Hi Guys,
    Got a question for you?
    I bought a mh721 about 3 years ago I haven’t used it in 2 years, been using a silhouette cameo as most of the stuff I was doing didn’t need the 2ft cutter.
    I have since bought a mh3516 and a computer package and those work together great.
    I’ve just spent 4hrs trying to set up the mh721 again on the same machine as the mh3516, will the two cutters conflict or should I be able to run both cutters simultaneously so there ar cutting at same time, I will be using to softwares flexi sign pro and sign blazer elements.
    Robert
    Jonathan feeney replied 8 years, 4 months ago 1 Member · 1 Reply
  • 1 Reply
  • Jonathan feeney
    23 July 2017 at 23:33
    Robert I have the exact same set up , i set my smaller machine up using the disk that was with it and set it up as a new printer then when cutting in sign blazer you just need to be sure to select the correct machine from the drop down cheers
