Home Forums Sign Making Discussions Vinyl Upcoming job etched vinyl
  • Upcoming job etched vinyl
    Posted by Daniel Taylor on 19 July 2018 at 12:20
    Hi I’ve been asked to quote an upcoming job which requires etched vinyl fitted to the centre of the glass panel at 1220 x 1500mm and thereis around 10 to do … this is obviously a 2 man job and will require around 20m of 2220mm etched vinyl … what would you say a reasonable quote per window would be ? I was thinl By around £80 fitted, does this seem reasonable ? Cheers
    Chris Windebank replied 7 years, 4 months ago 2 Members · 3 Replies
  • Stuart Miller
    19 July 2018 at 14:59
    Depending which etch effect you use as Standard Frost is half the price of Dusted, Silver or Crystal I charge at £30 to £35 per sq metre plus £5 per pane .
    So for each pane I would charge about £60 – £69 so £690 for the 10.
    It would only be a 1 man job though.
    I would buy it as 15 – 20 metres of 1220 wide so only have to cut it across at the length you need
  • Chris Windebank
    20 July 2018 at 09:50
    With Stuart on this, my local price is 30.00 per meter, London higher costs
    One man job and use standard frost
  • Chris Windebank
    Total for local 540.00 plus vat plus travel
