Home Forums Printing Discussions Uniform Printers uniform cadet wiper blades, help sourcing please?
  • uniform cadet wiper blades, help sourcing please?
    Posted by mark britton on 11 April 2019 at 07:19
    every time i turn machine on it states replace wiper blades. blades have been replaced how do i remove this message
    Stafford Cox replied 6 years, 8 months ago 2 Members · 2 Replies
    11 April 2019 at 08:57
    How did you replace the wipers? Did you go through the service menu procedure which should automatically clear down the message or did you do it some other way? The correct way is to go into the service menu scroll through – select maintenance – replace wiper blade and follow the instructions on the panel. Once complete press enter and the machine will go through a cleaning cycle followed by switching off the sub power. When powered up again the message should no longer appear
  • Stafford Cox
    11 April 2019 at 19:28
    Can you power on holding the cleaning button on these? It’s been a while.
